Remote Access - Java4Shell (CVE-2026-114938): how to protect your server
A critical Java vulnerability, CVE-2026-114938 (“Java4Shell”), was disclosed on November 17, 2026. TSplus Remote Access may be affected, because its HTML5 web server runs on the Java 17 runtime (Eclipse Temurin) installed by our setup. We are not aware of any attack against TSplus.
TSplus Remote Support, TSplus Advanced Security and TSplus Server Monitoring are not affected.
Is my server affected? Only if all of these are true:
The server runs Java 17.0.6 or newer. The Java runtime installed with TSplus is in this range.
The server CPU supports AVX-512 VBMI: Intel Xeon Ice Lake, Sapphire Rapids, Emerald Rapids or Granite Rapids, or AMD EPYC/Ryzen Zen 4 or newer. Older CPUs are not affected.
The attacker builds an exploit for one specific application. This is complex: it is sensitive to network conditions and often needs several attempts.
Mitigation (2 minutes)
Open
C:\Program Files (x86)\TSplus\Clients\webserver\runwebserver.ini. This is the default path; adapt it if you installed TSplus elsewhere.Add
-XX:-UseBASE64Intrinsicsat the end of the first line.Restart the TSplus web server.
This turns off only the vulnerable Java feature, with no noticeable impact on TSplus Remote Access performance.
Alternative: -XX:UseAVX=2 disables AVX-512 completely, with a wider impact. Use only one of the two options.
Note: if your server runs TSplus 17.20.9.2 or older, check this setting again after each update.
Permanent fix
A TSplus Remote Access update automatically installs the latest Java 17 runtime. It will include the fix as soon as Eclipse Temurin publishes it. This requires access to api.adoptium.net, and the fix is active only after a reboot or a web server restart. Servers without internet access need a manual Java update. We will publish a new entry when the fixed version is available.
If you have any questions or face an issue, please contact our Support team.
Thank you for keeping your servers secure!
Thomas Montalcino
CTO @ TSplus
