Ability to create mapped printers as per Terminal Works
Ability to create defined local printers on server which are mapped locally
eg EPOS mapped to local slip printer, LABEL mapped to local label printer.
It may be possible to do this already we just haven’t discovered how
Log in to comment and vote
Comments7
Thomas Montalcino
Mar 20
If the printer name can contain either the session id or the username, then this documentation will help you set-up Virtual Printer feature:
https://docs.tsplus.net/tsplus/virtual-printer-2/#how-to-customize-the-name-of-the-virtual-printer-mapped-devices. Thank you.
Nicole Wenschuch
Feb 13
Hello, I think the new virtual printer v2, which has been implemented for several versions now, would be suitable for your case. Printer names are passed through here.
https://docs.tsplus.net/tsplus/virtual-printer-2/#breaking-change
softideas
Feb 13
Hi, We may have been doing something wrong but we failed to create a single printer name eg EPOS for multiple users. If it is possible we will try again
softideas
Feb 13
Just tried and printer name appears to have to be unique per user session
What we use currently provides a single named printer that we can set for all users within the server based application.
We’d much rather use TSPlus for the complete solution as we’ve been using the product for many many trouble free years
Thomas Montalcino
Feb 19
The requirement of having the same printer name for every session may be achieved if the printer is available from the network for both clients and Remote Access server. Printers available through RDP connections will be named differently (e.g. “Printer name (redirected X)” for standard Windows redirections or Printer name DOMAIN\Username for Virtual Printer v2, as the printer name must be unique.
Would sharing the printer over the network a viable solution for your case ? After that, it is quite possible to remove all redirected printers from RDP connections.
softideas
Feb 21
Server is located our data centre printer at client store, so not an option. Stuck with Terminal works.
Eléana Pace
May 22
Our printing solution Universal Printer uses one printer which can redirect to one or several local printers depending on the user. Would that solution better suit your need than Virtual Printer?
https://docs.tsplus.net/tsplus/universal-printer/
