Activate license without maintenance & enable it later (API / CLI)
We currently activate TSplus licenses via command line (VOL) during VM provisioning.
Our requirement is to:
activate a license without maintenance
enable maintenance at a later time
manage both operations via API or CLI, without manual interaction on each VM through the portal
Is there currently a supported way (API, CLI, or documented procedure) to enable maintenance after license activation in an automated manner?
If not available today, is this functionality planned?
Log in to comment and vote
Comments2
Thomas Montalcino
Feb 19
This capability is not planned as a Volume License license or a subscription will always includes Update & Support. Thank you.
megi
Feb 19
Hello Thomas,
Thank you for your clarification.
In our case, we are using Volume Licenses (Enterprise edition) and the Update & Support does not appear to be activated automatically.
According to the official documentation:
https://docs.tsplus.net/it/tsplus/volume-licensing-activate/
we tried to use the following command to add the missing support:
(we are replacing
YOUR-VOLUME-LICENSE-KEYwith our actual Volume License key)However, the command fails and returns an error.
Our TSplus version is:
17.2025.6.27
Also, to clarify, we are using the Enterprise edition, not Printer.
Could you please confirm:
Is
/activate-supportsupported in version 17.2025.6.27?Is there any specific requirement for Enterprise Volume Licenses?
Is there a different procedure to activate the support period for Enterprise VL keys?
Thank you in advance for your help.
Best regards,
Megi
