TSplus Remote Access - More compatibility, stability, and secure Web access
TSplus Remote Access v19.50.9.22 delivers broader compatibility with the latest Windows Server 2012 R2 and Windows 11 updates, while improving the reliability of application publishing and portal connections. This release also strengthens web security with FIPS support, among other security improvements.
Here is the complete changelog for the TSplus Remote Access 19.50.9.22 release:
Improvements
  • Compatibility: TSplus is compatible with Windows Server 2012 R2 latest updates
  • Web Application Portal: an error message is now displayed and the applications are disabled when no application server of the farm is able to open them
  • Web server (v8.94): W.UniversalPrinterOwnPortLink now defaults to "*" to use the server’s local port and avoid browser port mis‑detection, especially behind proxies
  • Web server (v8.94): Added popup_download_renamed_files (default 3) to control auto‑download on file rename under \tsclient\WebFile; values 0–4 tune or disable the trigger
  • Web server (v8.94): Added temp_file_on_rename_popup (default ".tmp|.temp") to auto‑download when known temp extensions are renamed; can be disabled or extended
  • Web server (v8.94): Added FIPS support for RDP‑style security; enable via W.fipsenabled = "yes" or accept server‑enforced FIPS
  • Web server (v8.94): Enabled salted MAC by default for RDP‑style security when FIPS is off; disable via W.saltedmacdisabled = "yes"
  • Web server (v8.94): Fast‑Path input is reset on each reconnection to wait for client re‑advertisement
  • Compatibility: TSplus is compatible with Windows 11 24H2, 25H2 latest preview updates
Fixes
  • AdminTool: fixed unhandled exception occurring when trying to display the web portal customization
  • Web Application Portal: fixed the application servers assigned to a user being ignored, the portal sent the login without its domain to the farm controller
  • Phone To Session: users who didn't have Web portal 2026 will no longer have phone to session shortcut
  • Web Application Portal: fixed a false "session closed by the application server" alert when the user closes the HTML5 session tab shortly after opening an application
  • Web server (v8.94): fixed several graphic output issues for polling‑based connections (Web socket / native RDP unaffected)
  • Connection Client (v131): fixed embedded client PDF viewer is compatible with x32 and x64 architectures
  • AdminTool: fixed client download link button froze when clicked
