Remote Support – Users now approve incoming connections
New Remote Support client is out! Users can now be asked to accept an incoming connection before anything is shared or controlled. Administrators can enable it for the whole account or specific folders from the administration portal (documentation). Full changelog below.
Improvements:
  • Windows: added a setting to ask the user of the computer to accept an incoming connection before anything is shared or controlled, including with unattended access and the remote command prompt
  • Administration portal: account administrators can require the users of the computers of the account, or of some folders, to accept an incoming connection, and choose the delay to answer
  • Windows: improved performance of the remote screen display method on the viewer side
  • Windows: improved P2P support when connecting to a VM hosted on viewer workstation
  • Devices: faster search and smoother scrolling in the device list of the Windows client, the search text is kept after a refresh, and folders no longer collapse and expand again when the list loads
Fixes:
  • Devices: searching for a folder name now shows all the devices it contains, and devices stay in their folder when one of their parent folders matches the search
